XnView 1.90.2 very slowly opens Nikon D70s NEF (raw) files
Deni
Post by Deni »
With new version of XnView came a problem - raw files from Nikon dSLR - D70s are opening really slowly. It take more than 10 seconds to open that file. Much more time sometimes (up to 40 seconds!).
In older version (1.8.. something, I really don't remember and I've uninstalled it) everything was OK.
Is there a chance to quickly fix this problem? Or where I can download older version? Because I really don't want to start using IrfanView again ;-)
regards
Deni
Re: XnView 1.90.2 very slowli opens Nikon D70s NEF (raw) fil
Deni wrote:Hi,
regards
Deni
I'll upload a 1.90.3 next week...
Re: XnView 1.90.2 very slowly opens Nikon D70s NEF (raw) fil
Post by Guest »
xnview wrote:I'll upload a 1.90.3 next week...
Great news :) Thanks.
best regards
Deni
ggcanave
Pentax ist DL raw problem
Post by ggcanave »
Have the same problem with the raw files from the Pentax ist DL.
Hope 1.90.3 fix the problem.
regards
Guillermo
Post by Guest »
Unfortunately, 1.90.3 didn't fix the problem :( NEF files still opens very slowly...
Anonymous wrote:Unfortunately, 1.90.3 didn't fix the problem :( NEF files still opens very slowly...
Really??? More slowly than the 1.82.4??
pjp
Post by pjp »
I think yes (Nikon D200 - 10MPix). And more slowly as MRW (Konika Minolta A2 - 8MPix).
Pavel
pjp wrote:I think yes (Nikon D200 - 10MPix). And more slowly as MRW (Konika Minolta A2 - 8MPix).
Pavel
Could you try with 1.82.4 please. For me it's the same speed as 1.82.4
pjp
Post by pjp »
Sorry, for me not easy, because old version of XnView I deleted ... :-(
Pavel
pjp wrote:Sorry, for me not easy, because old version of XnView I deleted ... :-(
Pavel
You can download old version here:
http://download2.xnview.com/old_version ... win-en.exe
pjp
Post by pjp »
Thanks, I'll test and I'll write here result, but no early/later as next week.
Pavel
ggcanave
Post by ggcanave »
I got a better performace selecting "Embedded Thumbnail" in Browser, Preview option. I have a Pentax ist*dl and the raw format is .pef
pjp
Post by pjp »
sorry, it some. I opened RAW files from my network/server and I have in this net small problem :-(
Regards, Pavel
pjp wrote:Hi,
Regards, Pavel
Same as 1.82.4? So try to change setting 'Camera Raw'
pjp
Post by pjp »
OK, I didn't exact meassure time to open this type of file ;-)
I"ll check, thanks.
Pavel
