Save list of the last images open.
Timex
Post by Timex »
If we are using the program we have alot of images on diferents
folders for references.
Then when we must go to home close all the windows and the next day
must star to open all images, a cool idea will be until of close the
program have a boton or so called "save file list". and then the next
day when you start to work other once only must press the boton open
save list (or select a list file,or have file list in the desktop)and
when you press it the xnview open all the list images.
This would be a great help for all the comunity,its a hell are opening the images every day.
We HAVE the list !
:) Hello ! Welcome aboard !
• On the tool-bar, there is a small arrow-button beside the Open File button…
- Click it, and you'll have the list !
• However, you must check that the list is not purged when you exit XnView !
- So, go in the Options (F12) >> Interface >> Recent Lists section at the bottom of the dialogue.
- Verify that the two upper boxes be ticked, and the last one at bottom unticked !
• But indeed, that list is limited to the 10 last opened files…
- When it's full, the list is refreshed, and one old item is lost…
- Moreover, its background is always white, that is rather unpleasant IMHO…
- So, an improvement is desirable, maybe as an option in order to get a longer¦full list if one wishes…
and a BG like the Win theme, for instance. :P
:mrgreen: Kind regards,
