I would very much like to see a FTP Uploader option--I have used the one in [sorry] IrfanView and found it very useful although I do have WS_FTP and FileZilla and I run SeaMonkey 1.1.1 and XP PRO. It is just a thought as I enjoy your program very much.
JAS
FTP UPloader
Drahken
What I do is use SendToFTP, which is a tiny little prog that installs to windows' send to menu. You can then select any number of files, right click, and choose sendtoftp to upload them. This can even be done from within the open and save dialogs, which effectively allows it to integrate into any program.
Re: FTP UPloader
Ok, i'll create a plugin for that...jas wrote:I would very much like to see a FTP Uploader option--I have used the one in [sorry] IrfanView and found it very useful although I do have WS_FTP and FileZilla and I run SeaMonkey 1.1.1 and XP PRO. It is just a thought as I enjoy your program very much.
JAS
