Paint plugin v1.0
Paint plugin v1.0
Here is the first version of the Paint plugin: http://download2.xnview.com/beta/Paint.zip
For installation unpack the ZIP archive in program folder of XnView (e.g. C:\Program Files\XnView). Please note that the Paint plug-in works with the latest version of XnView (1.90.3), only.
In view mode, use menu Filter > Paint or "P" key to open the Paint dialog.
Nope !
• Sorry, I installed the addon, but there is not any Paint entry in the Filter Menu,
neither in French (with the original DLL) nor in English…
Re: Nope !
Strange, other users can use it??Clo wrote:• Sorry, I installed the addon, but there is not any Paint entry in the Filter Menu,
neither in French (with the original DLL) nor in English…![]()
Stitscher
Quite rotten !
—> marsh
Hello B. !
• Yes, right, I get unpacking errors here with TC, as well for the Paint addon as for the programme !
- I reported this to Pierre via IM, we are talking of currently…
FR
murthy363
- Yahoo Messenger: murthymsr
paint problem
I too faced problem in unzipping. tried with winzip as well as 7-Z.
both report CRC error.
winzip window reads "Bad CRC 6aad29 (shoul be 19857714)."
I am a lazy person, always searching for ways to avoid work and still manage the show !
My System : Win XP SP2 + XnView standard English version
murthy363
Re: Good ZIP
Thanks clo for the link, but sorry, when I click on the link 'HERE' provided by you, I get the error..Clo wrote:Hello!
• Pierre sent me the good addon, it's available HERE
• Works OK in English, but no menu entry yet in French, though the <P> key works…
- What about German, Stitscher ?
KR
However, i could copy the link:
Fatal error: main(): Failed opening required 'mainfile.php' (include_path='.:/data/apache/php/mmp_lib') in /data/members/free/multimania/fr/c/h/a/charries/htdocs/index.php on line 15
into the browser, I am able to download the paint.zip file.
JohnFredC
Hi Pierre:
No paintbrush?
I really like the functionality so far!
Before you go too far with the design, for me, having the separate popup window is not the best. I realize there may be limitations imposed by XnView's plugin architecture, but for me, paint should be applied directly into the currently viewed image (ie directly into the tab view, not in a popup)...
All such comments aside, though, this will be an extremely useful addition to XnView!
Here's how it looks on my system:
No paintbrush?
John
Troken
Link works
—> murthy363
Hello !
• The link works perfectly here , sorry, I just tested it at this moment.
• I'll try to place that archive on another server, so stay tuned !
EDIT : Please, try from THERE
KR
Stitscher
Re: Good ZIP
Thanks for the link, Clo.
Stitscher
