Crash when moving folders
omut
problem
Post by omut »
hi
when i'm trying to move more than 15 or 20 files from subfolder to parent-folder Xnview crashes
like this
problem is the same on network drives either on local drives.
there was no such problems in early Xnview versions (1.80)
please, help
sorry for my english
best regards, Anatoliy
Re: problem
omut wrote:hi
like this
Did you have the same problem in 1.90.2?
omut
Re: problem
Post by omut »
xnview wrote:
omut wrote:hi
like this
Yes
Re: problem
omut wrote:
xnview wrote:
omut wrote:hi
like this
Yes
So you are in a folder, you select some files, and drag&drop them in the parent folder (tree view), right?
omut
Re: problem
Post by omut »
xnview wrote: So you are in a folder, you select some files, and drag&drop them in the parent folder (tree view), right?
Yes, exactly
omut
Post by omut »
no fixes yet?..
omut wrote:no fixes yet?..
Difficult to fix because i can't reproduce it... :-(
Could you send your email by PM, i would like to send you a test version? Which OS do you have?
What does the error message in the above screenshot say?
Which Windows version do you use (XP, 2000, ...)?
