Key combos in Image View mode can NOT be used in Slide shows
Daniels
Post by Daniels »
The Help File for numerous versions has had [and still has as of 1.90.3] the following TIP [at the bottom of HELP|CONTENTS|
MISCELLANEOUS|KEY COMBINATIONS]:
'All the key combinations valid in the Image View mode, can also be used in Slide shows...'
But most all of those key combinations, such as DEL for Delete File, do NOT work in Slide Shows.
Don Daniels (ccp)
[email protected]
Medford NY USA
