[1.90.3] XnView does not work on Windows 95
imsai
Post by imsai »
Ahh... :-)
Re: [1.90.3] Win95 problem
imsai wrote:Ahh... :-)
Yes, currently 1.90 doesn't work on win95
aguirRe
Post by aguirRe »
I just noticed this too (Win95 OSR2), will it be fixed in an upcoming version?
Aokromes
Post by Aokromes »
I wonder if do you have any good reason to continue ussing windows 95, if you can upgrade to windows 98, at least it's a lot better.
ckit
Post by ckit »
I agree with Aokromes, I'll be trying Vista Ultimate 64-bit edition soon :)
If possible without too much effort, XnView should be runnable on Windows 95, too.
@Pierre: Could you please check and make a clear statement? If it's not possible, Windows 95 should not longer be listed as supported platform. And I guess the same applies for Windows 3.11.
helmut wrote:If possible without too much effort, XnView should be runnable on Windows 95, too.
For Windows 3.11, there is an old version
For Windows 95, i must build a special version, i'll do that asap
aguirRe
Post by aguirRe »
Thanks for the effort! :)
imsai
Post by imsai »
xnview wrote:For Windows 95, i must build a special version, i'll do that asap
Big thanks! :-)
