Support for the .eri (Entis Rasterized Image) not complete?
shadeless
Hi, lately I've found out that XnView doesn't open some files of .eri format (Entis Rasterized Image). Since the Photoshop with the official .eri plugin can open them, I am sure they are not corrupted, but XnView simply considers those files are with an unknown format. Is this a bug or it's a feature not implemented yet? I have the files with me but I am not sure if I can post the files here (2 files, one can be opened by XnView and one that can't, both are around 800KBytes).
Re: Support for the .eri (Entis Rasterized Image) not comple
Yes, please could you send me the filesshadeless wrote:Hi, lately I've found out that XnView doesn't open some files of .eri format (Entis Rasterized Image). Since the Photoshop with the official .eri plugin can open them, I am sure they are not corrupted, but XnView simply considers those files are with an unknown format. Is this a bug or it's a feature not implemented yet? I have the files with me but I am not sure if I can post the files here (2 files, one can be opened by XnView and one that can't, both are around 800KBytes).
shadeless
sample files
OK, here are the files:
1) The one that can be opened without problem:
http://www.filesend.net/download.php?f= ... c9d452da4d
2) The one that can not be opened (unknown format):
http://www.filesend.net/download.php?f= ... fc3c524b59
Thank you.
Thank you.
shadeless
about sample files...
Forgot to mention, I have more sample files here in case you need them to make comparison.
Re: about sample files...
Ok, i'll check the problem...shadeless wrote:Forgot to mention, I have more sample files here in case you need them to make comparison.
