When printing using DPI mode, the image is distorted. It only prints a small section of the image and this is all stretched to fill the page. Older versions of XnView never had this problem.
I have some screen grabs if that helps.
Print to DPI Problem
Re: Print to DPI Problem
Do you have the problem with all pictures?Guest RR wrote:When printing using DPI mode, the image is distorted. It only prints a small section of the image and this is all stretched to fill the page. Older versions of XnView never had this problem.
Two files showing what I'm getting:
http://www.readresearch.co.uk/personal/Clipboard-1.png
http://www.readresearch.co.uk/personal/Clipboard-2.png
And the image in question to try yourself:
http://www.readresearch.co.uk/personal/eragon.jpg
Right, i check...Anonymous wrote:Two files showing what I'm getting:
