More file handling functions
Sevensheaven
Post by Sevensheaven »
I'd love to see more Windows Explorer file management functions in XnView, such as easy moving, copying of files by dragging with the left and/or right mouse button, but also easy Zipping and Rarring of files, so we can also use XnView as a full-fledged alternative for that lame Windows Explorer.
Thanks and cheers,
Metin
Sevensheaven.nl — design | illustration | visualization | cartoons | animation
Re: More file handling functions
Thank you for your suggestions, Sevensheaven.
Moving/Copying file by dragging is available, already. Simply mark some files (thumbnails) in the XnView browser and drag them somewhere else.
Please note that dragging on the same drive (e.g. C:\ to C:\Temp) files will be moved, on different drives (e.g. C:\Test to D:\My Pictures), files will be copied. To change that behaviour, press Shift for moving and Ctrl for copying.
Related topic:
- How can XnView interact with other (graphic) programs?
foxyshadis
Post by foxyshadis »
An Explorer-ism I'd like to see replicated is, when dragging files to another folder and hovering over a closed folder, the folder will pop open. That's very handy sometimes.
foxyshadis wrote:An Explorer-ism I'd like to see replicated is, when dragging files to another folder and hovering over a closed folder, the folder will pop open. That's very handy sometimes.
Yes, opening a folder while dragging files is handsome and often needed. Actually this does work when dragging on the *folder* symbol or name, but not when dragging on the *"+"* symbol. So the functionality is there but not fully supported from the interface side.
Perhaps Pierre can add the "+" symbol for opening while dragging.
Sevensheaven
Thanks for your info Helmut!
Another thing I'd love to see is Windows context in the right-click menus, so we can do things like Rarring a file.
Cheers,
Metin
foxyshadis
helmut wrote:Yes, opening a folder while dragging files is handsome and often needed. Actually this does work when dragging on the *folder* symbol or name, but not when dragging on the *"+"* symbol. So the functionality is there but not fully supported from the interface side.
Hah! What do you know, I'm so used to using the + in explorer that I didn't even try that (although I have hazy memories of doing it the right way before; I'm just absent minded).
Probably my biggest annoyance when moving files around, is when dragging, the right-click button doesn't cancel the drag like most systems. Having to bring the mouse back to the icon or suffer a copy is only a little more effort, but, you know...
marsh
Post by marsh »
Sevensheaven wrote: Another thing I'd love to see is Windows context in the right-click menus, so we can do things like Rarring a file.
It is possible. All Current Hotkeys / Shortcuts
Dreamer wrote: Mouse shortcuts
Show default Windows Explorer context menu - Ctrl+RMB
Dret
Post by Dret »
This was my suggest about this problem:
http://newsgroup.xnview.com/viewtopic.p ... highlight=
:wink:
... without using keys but simply the Right-Button menù, like the windows File Manager.
:mrgreen:
Don't Panic!!!
