Tab closing at the tab
GulDukat
Is it possible to add the functionality to close a tab by clicking an X at the end of the tab? Just like Firefox has?
Take the time to appreciate the nature around you.
Re: Tab closing at the tab
It's a request already askedGulDukat wrote:Is it possible to add the functionality to close a tab by clicking an X at the end of the tab? Just like Firefox has?
GulDukat
Ah, may I assume you agree with such a functionality then? I searched for it prior to making the request, but couldn't find it. I just installed the program today and it was the first "annoyance" I came across, I'll let you know if I find more. Keep up the good work!
Right, latest versions of FireFox 2.0, Internet Explorer 7.0 and Eclipse 3.1 offer this for example. I think this gets more and more standard, so this makes sense for XnView, too.
Already, there are several ways to close the current tab, already:
Keyboard: Esc
Keyboard: Ctrl + W
Keyboard: Ctrl + F4
Mouse: Menu item "File > Close"
Mouse: Middle mouse button on tab
Mouse: Right click on tab and "Close this tab"
Mouse: Double left click on tab
Keyboard: Esc
Keyboard: Ctrl + W
Keyboard: Ctrl + F4
Plus…
—> helmut
• Hi!
• And you could add:
- Mouse : Double L.M.Button closes the tab too…
• About the [ × ] button on, I'm not very enthusiastic, I've that in the Opera browser, and it's not a wonder…
G.
• Hi!
Re: Plus…
Added.Clo wrote:- Mouse : Double L.M.Button closes the tab too…
It's a bit more intuitive than the above key and mouse button combinations, but it uses up some space. Usually most people have few images open at a time, so I think it would be o.k.. And perfect if it was configurable.Clo wrote:• About the [ × ] button on, I'm not very enthusiastic, I've that in the Opera browser, and it's not a wonder…
murthy363
- Yahoo Messenger: murthymsr
Re: Wider…
It is room consuming, agreed.Clo wrote:Again…
• Yes, it's wider and room-consuming, it's the reason for which I don't like a lot…
• Optional should be acceptable, though…
G.
My preference is to use the double LMB click to close the tab instead of 'X'
I am a lazy person, always searching for ways to avoid work and still manage the show !
My System : Win XP SP2 + XnView standard English version
The best
—> murthy363
Hello !
KR
• I do so too, IMHO, it's the most convenient…… My preference is to use the double LMB click to close the tab instead of 'X'
GulDukat
You could of course use a higher screen resolution to negate room consumption
I know there are key combinations, but each program tends to have different hotkeys and I don't want to learn new keycombinations for each program I use.
I knew about the ctrl+w as it is indicated in the menu, however, the esc option does help too. A X on the tab is probably also more of a "go with the flow" thing and isn't that bad at all IMHO.
PS1: what is "strfg" on your keyboard???
PS2: middle mouse button is often configured as an auto-scroll feature and xnview has not changed that functionality, so that doesn't work for me either.
And a microscope…
—> GulDukat
Hello!
• Yes, and also mount a microscope in front the screen to read the texts
and to see the small icons in the programmes I use!
• Like I said above, double LMB click does the trick for me, and optional should make everybody happy !
KR
65 soon…
…You could of course use a higher screen resolution to negate room consumption
65 soon…
GulDukat
foxyshadis
In firefox, the [x] only shows up when you hover over a tab. iirc Opera works that way as well. So the extra space taken up would only be when the mouse is hovering over the tab, if done that way. I'd personally hate having an x at all times, but wouldn't mind it showing up on hover at all.
Optional is easy but it's a cop-out unless there's no viable alternative; it's worth bearing in mind the question of whether it's worth adding to an already overcrowded options panel. Sometimes features should be cut instead of implemented half-baked as options, as well.
Are you sure ? Ha ha !
• I've Opera V. 9.10 French (8 hours spent to correct the FR-file…), and the [x] button is always displayed…In firefox, the [x] only shows up when you hover over a tab. iirc Opera works that way as well. …
- The settings are a pain in the b**, and I use that browser as a subsidiary one for some special cases only.
- So, it's possible I have missed some option to get the [x] button like you say…
• From my point of view, even an INI entry to change by hand could do the trick as option,
it shouldn't cause a too big work for Pierre…
