Visualiser images dicom sous xnview
Laurent
Post by Laurent »
:idea: J'ai des images en formats dicom mais sans extensions que je souhaite ouvrir. Mais à part faire planter xnview lorsque j'essaie de visualiser l'image après lui avoir ajouter une extension, je ne parviens ni à les visualiser et encore moins à les convetir en jpg. Merci pour l'aide qui peut être apporter.
Mauvais forum - Wrong forum
:) Good evening, bonsoir
• You are in the English forum… There is a “French” section here too…
(Vous êtes dans le forum Anglais… Il y a aussi une section “Français“… ;) )
:mrgreen: KR - Cordialement,
Laurent
Post by Laurent »
Sorry,
I would like to read dicom format but the files I got, even they are dicom format, haven't any extensions. I tried to add manually some extensions but xnview crash in this case. I would like to read and to concert my images. How to do it ?
Thanks for your help.
Go to Tools » Options... » Browser » File List » Misc and de-activate Recognize only by extension.
Laurent wrote:Sorry,
To be able to read dicom picture, file must have .dicom or .dic extension
Franz
Using XnView for DICOM Images with "wrong" extensi
Post by Franz »
I am using DICOM Images with ".IMA" extension (created by Siemens-Syngo) - When the first file in Folder is renamed to ".DCM" the viewer of xnview can display all other files although their extension is still ".IMA" (why?).
Is there a workarround to assign the ".IMA" extension to DICOM files?
Re: Using XnView for DICOM Images with "wrong" ext
Franz wrote:I am using DICOM Images with ".IMA" extension (created by Siemens-Syngo) - When the first file in Folder is renamed to ".DCM" the viewer of xnview can display all other files although their extension is still ".IMA" (why?).
No, dicom files must have dcm extension to limit crash...
