Save XMP
kurka666
Save XMP
Post by kurka666 »
Hi
Have you got any plans to allow saving of XMP? After I have installed Adobe Lightroom on my PC, all my images suddenly got an XMP block in them, so if I continue to tag my images using IPTC only, I may find that some programs will use the XMP block only (thus causing inconsistency in the data)
I'm not looking for any XMP-functions as such - just a way to read and store the whole XMP block as a long text string.
thanks
Re: Save XMP
kurka666 wrote:Hi
thanks
Ok, i'll add it
kurka666
Post by kurka666 »
superb! :-D :-) :-D
kurka666
Post by kurka666 »
Is this added in the latest version?
kurka666 wrote:Is this added in the latest version?
Yes, you have gflBitmapGetXMP
kurka666
Post by kurka666 »
Thanks, but I mean WRITE XMP? I'd like to be able to use the getXMP-function to read it, and then make changes and write it back. Possible?
thanks
kurka666 wrote:Thanks, but I mean WRITE XMP? I'd like to be able to use the getXMP-function to read it, and then make changes and write it back. Possible?
thanks
Ok, i'll add it
kurka666
Post by kurka666 »
Excellent! This is just what I'm looking for.
Do you know approximately when you will have a new version with this function built in?
Thanks a lot
