Crashes when viewing .c4 files
stevegates
Post by stevegates »
I am using XnView ver 1.90.3 to work with c4 files. It works great with most of the files. However, there are a few that cause XnView to crash (close) if i try to view them. I get the following error msg:
The instruction at "0x006164c5" referenced memory at "0x0249300". The memory could not be "written".
Using windows 2000 service pack 4. I have also tried to open some of the same files on a another computer using winXP SP2. XnView also crashes on that computer.
Any solutions? :?:
Steve
Re: XnView Crashes
stevegates wrote:I am using XnView ver 1.90.3 to work with c4 files. It works great with most of the files. However, there are a few that cause XnView to crash (close) if i try to view them. I get the following error msg:
Any solutions? :?:
Could you send the files?
stevegates
Re: XnView Crashes
Any solutions? :?:
One is on the way
Thanks
Steve
Steve
stevegates
Fix?
Any luck with a fix?
Steve
Re: Fix?
stevegates wrote:Any luck with a fix?
I don't understand why there is a crash in the fax decoding...
