Categories Getting Duplicated When XnView Started
J Smith
Post by J Smith »
Categories contains preprovided categories of audios, drawings, icons, photographs, pictures and videos.
Whenever I open and close XnView the program is duplicating each of these categories. I have deleted them only to see them com back. Once I had 35 entries of each.
I had one user category. It is not getting duplcated.
I run under Win 98SE.
Re: Categories Getting Duplicated When XnView Started
J Smith wrote:Categories contains preprovided categories of audios, drawings, icons, photographs, pictures and videos.
Each time that you start xnview, all default categories are added again??
J Smith
Post by J Smith »
Yes.
I went back and tried it again. I deleted all but one of each category.
I closed XnView.
I started it again and looked in categories. I saw two of each.
J Smith wrote:Yes.
I closed XnView.
And the next time, three??
J Smith
Post by J Smith »
Yes.
J Smith wrote:Yes.
Could you contact me by emai or PM, please
J Smith
Post by J Smith »
I sent email to [email protected] with images of the categories screens showing the categories repeated 3 and four times.
I did some more work on the problem.
The thought occurred to me that the code may be repeating the categories when I open it because it thinks it needs to rebuild the categories data base. Something might be triggering that code.
I might have deleted the data bases once in the past.
So I decided to uninstall xnview and reinstall it. I thought that might recreate the database once and it might work from then forward.
This would eliminate anything in my .ini files as possible causes.
After several uninstall and install cycles I finally deleted categories.db and xnview.db, all the xnview files, and did what I think was a clean install.
I had to go through several cycles to find the data bases in c:\windows\application data.
When I restarted xnview the first time I saw the categories once.
I also observed that XnView created xnview.db, categories.db, and xnview.ini in c:\application data\xnview directory after I started the program, not during the install.
So there is code on the program, as opposed to the install, that creates the default categories.
I then started xnview a second time and saw the problem again: the categories were repeated twice.
The only unusual things I know of about my installation are Win 98 SE and I have the xnview directory on drive f:\program files\xnview instead of c.
It looks to me like something is erroneously triggering the code that writes the default categories when they already exist in the data bases.
J Smith wrote:I sent email to ... with images of the categories screens showing the categories repeated 3 and four times.
Sorry but i have not received your email. I would like to send you a test version too...
J Smith
Post by J Smith »
Another copy of images sent May 9, 2007.
J Smith wrote:Another copy of images sent May 9, 2007.
Nothing???? :-(
J Smith wrote:I sent email to [email protected] with images of the categories screens showing the categories repeated 3 and four times.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=9]Welcome![/url]) wrote:Welcome in the XnView forum! We hope that you like and enjoy the graphic viewer XnView. If you have questions or problems with XnView, Nconvert or GFL SDK, you can posts your issue, here. Also, you can mail me directly via Image. Your feedback is most welcome!
J Smith, maybe it's better to use the “contact” address (instead of the “webmaster” one) for sending samples.
