GflAfx can read some IPTC metadata fields, but can't (or I can't find) any means to read photograph EXIF info. Are you planning to include this some time?
Would be great for photographers and photograph applications.
Thank you in advance.
Do you plan to include the possibility to read EXIF?
_GUI_
Re: Do you plan to include the possibility to read EXIF?
You can read EXIF with EXIFGetByID_GUI_ wrote:GflAfx can read some IPTC metadata fields, but can't (or I can't find) any means to read photograph EXIF info. Are you planning to include this some time?
_GUI_
