Can not open or convert big Jpeg file ( ~130 Mb)
toon
Post by toon »
If i am try open that file in XnView 1.90 popup message "Out of memory" in version 1.90.3 this message not upper and file can't open. That file prefect open in ASDSEE 6 and Photoshop 7.0.
foxyshadis
Post by foxyshadis »
Well, it seems to be a design limitation. Photoshop can handle 900 megapixel images since it swaps out to disk, ACDSee might be the same, but xnview never will. What are the dimensions and bit depth of your image?
Although it may get such capabilities at some point in the future, you'll just have to live with using something else for gigantic images for now.
toon
Post by toon »
Resolution of image 27029 x 25162, 72 dpi, RGB 24 bit. Its airmap image.
toon wrote:Resolution of image 27029 x 25162, 72 dpi, RGB 24 bit. Its airmap image.
Currently there is a limitation, i'll fix it
foxyshadis
Pierre, can you actually fix it to work with an image that requires nearly 3GB of memory? Are you implementing a new swap system, or is that just for 64-bit builds?
foxyshadis wrote:Pierre, can you actually fix it to work with an image that requires nearly 3GB of memory? Are you implementing a new swap system, or is that just for 64-bit builds?
Currently not, the limit is 3Gb
