Thumbnail labels
Fund-A-Mental
Thumbnail labels
Post by Fund-A-Mental »
Just installed 1.90.3 version of XnView.
I have selected some EXIF options to show under thumbnails in Options -> Thumbnails -> Thumbnail Label, but they didn't appear as it was in older version. I'm sure the pictures has EXIF in it, I see "EXIF" mark on thumbnails and see EXIF options in Properties window(Alt-ENTER). Is it a bug or I have missed something?
Fund-A-Mental
Sorry, the OS is Windows XP PROF SP2
Re: Thumbnail labels
Fund-A-Mental wrote:Just installed 1.90.3 version of XnView.
But do you are in thumbnails? or Thumnails+label?
Fund-A-Mental
That is my problem! Thumbnails + labels works fine. Thanks for your help!
Ampa
thumbnails with or without labels...
Post by Ampa »
Just updated to 1.90.3 and noticed that the view options 'Thumbnails' and 'Thumbnails with Labels' act in reverse...
ie If I select 'Thumbnails', I get labels. If I select '...with Labels' I only get thumbnails.
Ampa
WinXP SP2
Re: thumbnails with or without labels...
Ampa wrote:Just updated to 1.90.3 and noticed that the view options 'Thumbnails' and 'Thumbnails with Labels' act in reverse...
Reverse???? I have no problem...
I think there's might be a misunderstanding and one problem:
"Thumbnails" and "Thumbnails + Labels"
What the two views do:
- View "Thumbnail" shows a thumbnail and a label. If checkbox "Show filename in 'Thumbnail' mode" is unchecked, the thumbnail will be shown, only.
- View "Thumbnail + Labels" reads "Thumbnail + Custom labels". Depending what custom lables you have choosen, the number of labels might range from 0-10.
EXIF data not shown
There might be a problem with the EXIF data. Please check whether your EXIF data is shown properly in the tab "EXIF". If yes, there might be a problem in XnView, if no, there might a problem with the EXIF data. There are known issues with EXIF data written by Adobe PhotoShop, for example.
Ampa, you might also want to consider checking the status of this setting:
Tools » Options... » Browser » Thumbnails » Appearance » Show filename in 'Thumbnail mode'
