saving search criteria/search favorites
stax
Post by stax »
although XnView has a huge feature set, some users always will miss some features, it's impossible to serve everybody. MediaMonkey addresses this by providing a extensive COM/WSH SDK. There are two minor things I miss:
1.) In order to easily find all wallpapers with a certain dimension I would like to request a feature to save search criteria, like how Agent Ransack does it, virtual folders in Thunderbird or AutoPlaylists in MediaMonkey.
For now I made a simple search, display detail view, sort for dimension, drag to a category, quite a few steps to perform all the time. Maybe there is a simple workaround or a simple way adding a solution. Sometimes it happened to me I thought adding a feature is gonna be hard or is not gonna be needed so I forget the idea and then all of the sudden I had a idea for a really simple or useful solution. At some time I'm hoping you'll have a scintillation on this issue :)
2.) Is it possible to show a image fullscreen when double-clicking a thumbnail?
many thanks,
Frank
Re: saving search criteria/search favorites
stax wrote:Hello,
Yes, a good feature...
Yes, option/keyboard/Switching mode
stax
Post by stax »
Thx, it seems the search in Vista which is also available for XP (Windows Desktop Search/Live Search) can also do it. MS got the query syntax right IMHO, my query is:
ext:jpg width:1024 height:768
works great, the query can be saved to the favorites :D
http://search.msn.com.sg/docs/toolbar.a ... ntax.htm#A
