I don't know how to add Watermark!
heisekaidangku
Post by heisekaidangku »
My english is bad!
XnView is a good soft!
I can use it batch convert pictures.
But,If i want to batch add watermark,i don't know how to do.
and i only find a dialog can add text!
thanks!
Re: I don't know how to add Watermark!
heisekaidangku wrote:My english is bad!
thanks!
I'll add soon 'watermark'
heisekaidangku
thanks!
Good! I don't know if it can use PNG format?
if that,the "Watermark soft" will be killed!
Waiting…………
heisekaidangku wrote:Good! I don't know if it can use PNG format?
Once available the watermark function will applicable to all the image formats supported by XnView.
Training…
—>heisekaidangku
:) Hello !
• Waiting for that useful addition, you could get a clue about the watermark handling,
since it's already available from the “Paint” tool : Filter Menu >> Paint in 1.90.3.
- You could get an info from THIS TOPIC online (might be added to the official Help too…).
- However, just as a “training”, because indeed the batch handling is not supported from the “Paint” tool…
- For such tries, please use copies !
• Like helmut says above, all image-formats supported at writing can be used,
as well for the main image, as for the watermarked background…
- Some features are missing still, i.e. to tile from a small image…
:mrgreen: Kind regards,
