Numbering in slideshow
Duchess
Post by Duchess »
I'm new on this forum. I have XNView 1.82.4 version and I really like it a lot. That's Great!! Thanks to the Author!
But I have one small problem: whenever I put numbering on the pictures, like _01 etc.... and then watch a slide show, the pictures are shown in such order:
01 to 010 and then 100.
so it's not in simple order like 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11....
Can anyone help?
Thanks a lot!!!
Re: Numbering in slideshow
Duchess wrote:Hello,
Can anyone help?
If you use 'name (numeric)' as sorting method in the browser, the order will be good...
Post by Guest »
Can anyone help?
Thank you, Pierre.
But I dont have Numeric name in Slide show window. there's only Name, and if you click on it, then you see this order:
01 to 09 and then 100, 101....
Anonymous wrote:
Thank you, Pierre.
No in the browser view, before to start slideshow dialog
Post by Guest »
xnview wrote:
Anonymous wrote:
Thank you, Pierre.
Nothing changes... still 09 and then 100... :(
Anonymous wrote:
xnview wrote:
Anonymous wrote:
Thank you, Pierre.
?? could you post a screenshot of the slideshow dialog?
Post by Guest »
xnview wrote:
Anonymous wrote:
xnview wrote: No in the browser view, before to start slideshow dialog
I'll send you an email with a screenshot
thanks
Anonymous wrote:I'll send you an email with a screenshot
A post with screenshot would be much better because forum users can also see. Please see topic "Using ImageShack to upload sample images" for an easy way to upload images.
Post by Guest »
the website imageshack is filtered and blocked here :(
Moreove, Pierre's email doesnt work :(
Post by Guest »
But, one good thing:
If you open Slideshow dialog, and press Add, and select all pictures, then the order is fine.
but if you press Add folder, then the order is 1 to 9, and then 100, 101...
Maybe this will help to understand the problem and fix it.
thanks a lot!!!
Anonymous wrote:the website imageshack is filtered and blocked here :(
Hmm. Not good. :-|
Anonymous wrote:[Moreove, Pierre's email doesnt work :(
Have you tried Image?
Post by Guest »
Hmm. Not good. :-|
thanks, I will.
no, I tried the one which is on Pierre's profile.
Dreamer
Post by Dreamer »
Hmm. Not good. :-|
I have problems with imageshack too, uploading works good, but some images are not shown, perhaps it's a some limiting (of countries)?
http://imagevenue.com/ works good here.
Dreamer
