when choose chinese language Create web page will result...
heisekaidangku
Post by heisekaidangku »
when choose chinese language Create web page will result distortion.
I check the WebTemplate,found that:
<DOCTYPE>
<html>
<head>
<meta>
<meta>
<meta>
<title>XnView Thumbnail</title>
</head>
<frameset>
<frame>
<frame>
</frameset>
</html>
charset is utf-8
I don't know how to change it.
who can help me? :( thanks!
Re: when choose chinese language Create web page will result
heisekaidangku wrote:when choose chinese language Create web page will result distortion.
<DOCTYPE>
<html>
<head>
<meta>
<meta>
<meta>
</head>
<frameset>
<frame>
<frame>
</frameset>
</html>
charset is utf-8
What do you means by distortion??
heisekaidangku
<DOCTYPE>
<html>
<head>
<meta>
<meta>
<meta>
</head>
<frameset>
<frame>
<frame>
</frameset>
</html>
charset is utf-8
See the pictures
<DOCTYPE>
<html>
<head>
<meta>
<meta>
<meta>
</head>
<frameset>
<frame>
<frame>
</frameset>
</html>
charset is utf-8
See the pictures
Ok, a problem with '()' charaters, i fix it
Is it possible to send me your email by PM, i would like to send you a version?
heisekaidangku
xnview wrote: What do you means by distortion??
See the pictures
I fell that the problem is not only '()' !
You can see the pictures carefully.
In english version the characters like"next and previous" are ok.
but in chinese version is distortion.
I don't know what cause the BUG! language file?
heisekaidangku wrote: You can see the pictures carefully.
Could you send me a PM with your email, please
heisekaidangku
xnview wrote:Is it possible to send me your email by PM, i would like to send you a version?
Thanks very much!
I have send my Email by PM.
XnView is a good software.It can support VISTA OS perfectly!
