Hi
I might be missing something here but, is it possible to use batch conversion while preparing web albums from XNView?
As far as I can see images can only be resized in "Web page create" dialog.
Many thanks for the fenomenal software.
Batch conversion + web album creation
Re: Batch conversion + web album creation
Which process do you want to make?zinek wrote:Hi
zinek
webalbums
I wanted to do some typical stuff like sharping, saturating etc. (2-3 transformations at most) since I had a feeling that image resizing done during web page creation kind of significantly lowered quality of the image.
So, the fairly easy workaround was to use Batch Convert to transform images, and then just copy them into the "images" folder within the album folder.
Not really an issue, but I thought there might be something I'm missing which would enable me to use "Batch convert" (which btw works great) during web album creation.
Thanks
Thanks
