Cannot Convert certain Adbobe Illustrator CS files
Post by Guest »
I am currently researching available command line image converter tools for use with Adobe Illustrator .AI files.
XnView seemed very promising but I am running into errors with a subset of files and cannot find any resolution. Ghostscript is installed and I can successfully convert some files but not all.
Any ideas? Any help would be greatly appreciated...
Re: Cannot Convert certain Adbobe Illustrator CS files
Anonymous wrote:I am currently researching available command line image converter tools for use with Adobe Illustrator .AI files.
Ghostscript can convert all AI files, could you send me a sample?
