Resize with "Screen size" in % -> "Print s
veleb
Post by veleb »
versions: xnview 1.74, xnview 1.90.3, Win XP
When you try to resize an image
and "Screen size" is in %
when you enter "Print size" Width or Height, the same number is shown in the other input box
(Keep Ratio on)
You have to change "Screen size" to pixels to fix this.
Re: Resize with "Screen size" in % -> "Pri
veleb wrote: You have to change "Screen size" to pixels to fix this.
Right...
