Very small thumbnails for Pentax RAW files
GuestTom
Post by GuestTom »
Hallo,
in the xnview version 1.90.3 my Raw-files (Pentax K10D PEF´s) are only shown as very small (horrible) thumbnails. I use emedded jpg/thumbnails, but in all older versions, i saw the really good emedded jpg (displayed very fast) in full resolution 3872x2592.
Do I have to change any settings?
Thanks and regards
Tom
GuestTom wrote:Hallo,
Could you send me a file?
GuestTom
Post by GuestTom »
Hallo,
thanks, I´ll send a K10D PEF-File to you.
Tom
GuestTom
PEf File
Post by GuestTom »
several days ago I sent you the PEF-File. Did it reach you?
Best regards
Tom
Re: PEf File
GuestTom wrote:Hello,
Sorry i have not received it
GuestTom
PEF-File
Post by GuestTom »
today I tried it again. I sent the PEF-file to <REMOVED>
I hope it works.
Best regards
Tom
Re: PEF-File
GuestTom wrote:today I tried it again. I sent the PEF-file to <REMOVED>
I hope it works.
I have no problem with this file.
The problem is in view/preview or the thumbnails??
GuestTom
PEF-File
Post by GuestTom »
By doubleclicking the thumbnail, in the xnview version 1.90.3, my Raw-files (Pentax K10D PEF´s) are only shown as very small (horrible) thumbnails. Doubleclicking the thumbnail in version 1.90.2, i see a really good emedded jpg (displayed very fast) in full resolution 3872x2592.
Tom
Re: PEF-File
GuestTom wrote:By doubleclicking the thumbnail, in the xnview version 1.90.3, my Raw-files (Pentax K10D PEF´s) are only shown as very small (horrible) thumbnails. Doubleclicking the thumbnail in version 1.90.2, i see a really good emedded jpg (displayed very fast) in full resolution 3872x2592.
Which setting do you have in option/View/Misc/Camera RAW
GuestTom
Pef-Files
Post by GuestTom »
In option/View/Misc/Camera RAW I have set "emedded thumbnail" (I always used this setting).
Tom
Re: Pef-Files
GuestTom wrote:In option/View/Misc/Camera RAW I have set "emedded thumbnail" (I always used this setting).
Here, i have a 640x480 picture (with embedded), could you post what you have?
GuestTom
PEF-Files
Post by GuestTom »
Yes, I have also an 640x480 in bad quality, but in the Version 1.90.2 there was a fullsize picture.
Tom
Re: PEF-Files
GuestTom wrote:Yes, I have also an 640x480 in bad quality, but in the Version 1.90.2 there was a fullsize picture.
It's a fix, if you want to have the full size, you must change that in Camera RAW settings
GuestTom
PEF-Files
Post by GuestTom »
But using "Raw halfsize", is not as fast as the "embedded jpg". Browsing through raw files was very fast and comfortably in version 1.90.2.
Can this fix in version 1.90.3 be canceled in the following one?
Tom
Re: PEF-Files
GuestTom wrote:But using "Raw halfsize", is not as fast as the "embedded jpg". Browsing through raw files was very fast and comfortably in version 1.90.2.
Tom
Ok, i'll try to change that
