Thanks for this new release. XNView is pivotal to my work flow.
The "Write options" in the IPTC dialogue are now permanently greyed out. I have tried a number of ways to activate it ... but with no success.
Thank you
Version 1.91 - IPTC dialogue problem
PSHRutPark
PSHRutPark
Re: Version 1.91 - IPTC dialogue problem
Further to the above. The problem only happens if 1 image is selected for IPTC editing.
If multiple images are selected then the IPTC dialogue options are as expected.
Yes, normal. Option are for multiple files...PSHRutPark wrote:Further to the above. The problem only happens if 1 image is selected for IPTC editing.
PSHRutPark
OK. I was mistaken regarding a single file. I must have always used it for multiple files in the past. Is there a reason why it's only limited to multiple files?xnview wrote: Yes, normal. Option are for multiple files...
My single image intended use was to append IPTC tags from a saved template to IPTC tags already present in the image.
Thanks.
Oh yes, right if you use saved template, you must have these settings! I'll change that...PSHRutPark wrote:OK. I was mistaken regarding a single file. I must have always used it for multiple files in the past. Is there a reason why it's only limited to multiple files?xnview wrote: Yes, normal. Option are for multiple files...
Thanks.
PSHRutPark
xnview wrote: Oh yes, right if you use saved template, you must have these settings! I'll change that...
Thank you.
I search someone to test IPTC feature before to release the 1.91.1, could you send me your email by PMPSHRutPark wrote:Thank you.xnview wrote: Oh yes, right if you use saved template, you must have these settings! I'll change that...
