Is it reel to making DLL for viewing thumbnails in windows explorer? For all xnView image formats, of course.
I just find something like this here: "Koshigaya ThumbnailSupport"
http://www.koshigaya.de/?content=tools
but this program not support exr, hdr and not work correctly from windows Vista. And It very slow for something formats (iff for example).
Thanks for good soft!
Re: thumbnails in windows explorer
You have XnView Shell extensionaliax wrote:Is it reel to making DLL for viewing thumbnails in windows explorer? For all xnView image formats, of course.
http://newsgroup.xnview.com/viewtopic.php?t=1144
You have
—> aliax
Hello !
• AFAIK, you can already watch thumb nails in Win Explorer - at least with XP - …
- You can see thumb nails in the file panels from XnView using Total Commander instead, for instance…
KR
- Forum Librarian
Re: You have
Hi CloClo wrote:- You can see thumb nails in the file panels from XnView using Total Commander instead, for instance…
I was curious about your proposed solution and did a little snooping around on Ghistler's sites:
TotalcmdWiki: ([url=http://www.ghisler.ch/wiki/index.php/Lister]Lister[/url]) wrote:Extensions
Additional file formats can be supported in Lister using:
- Lister plugins: Install them in the Lister Configuration dialog, you'll be able to load many non-standard formats in Plugins mode.
- IrfanView and XnView: Check corresponding option in the Lister Configuration dialog, you'll be able to load graphics other than BMP in Image/Multimedia mode.
In panels
• Indeed TC can display the thumb nails in the panels, provided by XnView (or else).
• Just look at the TC TUTORIAL
• Also described (for short) in our XnView Manual.
- Nothing to do with the “Lister” view you quote, this is another function…
BTW : The TC-Wiki is not really the good place to get such an info…
- I didn't even add a French section, that sucks, and I've no time to spend at this.
- Forum Librarian
OK, got it: Total Commander Tutorial » Configuration » Thumb-nails » Screenshot
Here's an XP-style screenshot from this forum:
[ Zoom ]
The Medal !
You win the Golden Medal of the TC-Tutos Trackers !Claude
- Forum Librarian
Re: The Medal !
Thank you, thank you,Clo wrote:You win the Golden Medal of the TC-Tutos Trackers !
... but I'm afraid I don't even deserve the bronze medal, as I wasn't able to come up with a screen grab of Total Commander with integrated XnView.
aliax
