new user, adobe-photoshop-plugins crashes
macc
Post by macc »
i have a problem with the function adobe-photoshop-plugins.
first it worked fine. and i was able to use some 8bf filters.
but the xnview crashed and i haven't been able the function anymore.
every time i want to start it or press CTRL + G an error message says: the application can't be started, because PLUGIN.DLL wasn't found. New installation could fix the problem.
OK, i installed xnview, but the function doesn't fix. it always gives me the error message.
could someon please help me, i 'm a new user to xnview, and have no further experience with it?
Re: new user, adobe-photoshop-plugins crashes
macc wrote:i have a problem with the function adobe-photoshop-plugins.
Do you have changed something? Try to locate plugin.dll on your disk, some adobe plugin use this dll
poula_x
Invalid UTF-8 strings error
Post by poula_x »
Hi friend, just like macc I am also having some problem with dll files. at first when I installed xnview adobe-photoshop-plugins it workes fine, but last night my computer had a crash at the time of applying xnview on a large image file. From then it's giving me Invalid UTF-8 strings error. I ave tried every possible way to fix it but failed. can any one help me here.
