Context menu Conversion bug?
Karelik
Post by Karelik »
Hi!
I tried to convert 20 images through XnView integration. I selected 20 images in TotalCommander, clicked Convert to GIF (in context menu) and XnView converted only one (first one). Same behavior - Explorer, Total Commander.
Is it bug or I do something wrong?
Czech WinXP:SP2, XnView 1.91
ckit
Post by ckit »
XnView can only handle one image at a time via the Shell Extension.
It's stupid, I know :(
Drahken
Post by Drahken »
I wonder if you could do it with nconvert?
Could you test this version? i've added multi file support
http://www.xnview.com/beta/XnViewShellExt.zip
ckit
Post by ckit »
Before I try this, is this 32-bit or 64-bit?
I only ask as you did recently create a 64-bit version as well.
ckit wrote:Before I try this, is this 32-bit or 64-bit?
It's the 32bits version
ckit
Post by ckit »
Ok, I just converted 3 JPG's to BMP with no problems :)
Thanks very much!
Karelik
Thanks
Post by Karelik »
Thanks a lot. Great function
