Sort/Select by EXIF or IPTC
JohnFredC
Post by JohnFredC »
Today I need to sort my images by ISO, then select only the ISO 1600 images.
So my request is to allow ANY arbitrary metadata value (or concatenated values) to be used for sorting and filtering.
It would be best if there was a "Custom" or "User" submenu in the filter and sort dropdowns (of the mini-toolbar) with Define and Save plus lists of the defined filters and sorts to select from.
John
Re: Sort/Select by EXIF or IPTC
JohnFredC wrote:Today I need to sort my images by ISO, then select only the ISO 1600 images.
Ok, good request...
