Nice improvements lately
Drahken
I used to use 3 seperate progs depending on what I needed them for, now I use xnview almost exclusively. I used to use irfanview for most of my image viewing because it loaded much faster than xnview, image analyzer for enhancing & optimizing images & for quick annotation type stuff (it used to be about the only viewer with a simple paint tool), and xnview for loading multiple images at a time or for opening or converting oddball formats. With the string of improvements lately, xnview has pretty much taken over all those functions. The load time was sped up a few versions back, the export function is great for optimizing, and now it has a paint tool as well. Now about the only time I use another prog is when I want to use an adobe plugin (the ones I use most just don't work in xnview, so I still have to use irfanview for them), and when I want to do some heavy duty editing or full function painting (things xnview was simply never designed to do).
Re: Nice improvements lately
Which adobe plugin don't work? And the speed to load is much faster in irf**** ??Drahken wrote:I used to use 3 seperate progs depending on what I needed them for, now I use xnview almost exclusively. I used to use irfanview for most of my image viewing because it loaded much faster than xnview, image analyzer for enhancing & optimizing images & for quick annotation type stuff (it used to be about the only viewer with a simple paint tool), and xnview for loading multiple images at a time or for opening or converting oddball formats. With the string of improvements lately, xnview has pretty much taken over all those functions. The load time was sped up a few versions back, the export function is great for optimizing, and now it has a paint tool as well. Now about the only time I use another prog is when I want to use an adobe plugin (the ones I use most just don't work in xnview, so I still have to use irfanview for them), and when I want to do some heavy duty editing or full function painting (things xnview was simply never designed to do).
Drahken
The speed -used- to be faster in IV, before you made it so that XNV remembered the list of plugins & addons from session to session. Scanning the plugins folder on every startup really slowed it down.
There actually seems to be quite a few adobe plugins that don't work in XNV, but the one I use that doesn't work is DCEtools. It has a colorcast remover & an auto enhancer that does smart smoothing (smooths solid areas without blurring edges). I mentioned the problem before
