Good tool ! Good job.
But <Edit> and 'overwrite all current value' seem not to work. Old value stay.
May be i did not use properly.
thank's for your help.
zzapp.
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?t=12711]IPTC write to all not working[/url]) wrote:Ok, if 'Replace only if current value is empty' is not enabled, there is a problem... I'll check...walhalla wrote:hi & thx very much!
i tried again and used the only thing, i have not tried before: i tagged all therr options at "combine..." -> "add new ...", "keep current ..." & "replace ...". it works (ONLY), if all options are tagged!?
i dont understand, but now i know and so i can keep on trieing your software!
