I would like to be able to drag & drop multiple images from XNView into Adobe Lightroom. It works for single images: all I do is select and drag a thumbnail onto the Lightroom icon -- this launches Lightroom and displays its import dialog. However, if I try to drop more than one image, Lightroom reports that "No photos were found to import." Any ideas on how I can drag & drop a group of images into Lightroom? Thanks,
Howard
Drag & drop images into Lightroom...
Re: Drag & drop images into Lightroom...
But drag&drop for multiple files works, for example with windows explorer....howardg wrote:I would like to be able to drag & drop multiple images from XNView into Adobe Lightroom. It works for single images: all I do is select and drag a thumbnail onto the Lightroom icon -- this launches Lightroom and displays its import dialog. However, if I try to drop more than one image, Lightroom reports that "No photos were found to import." Any ideas on how I can drag & drop a group of images into Lightroom? Thanks,
howardg
