Export without extension?
Yazor
Post by Yazor »
I choose command EXPORT and I save the picture. XnView save the picture without expansion JPG. Program behaves on several just the same computers. Why?
Re: Export without expansion?
Yazor wrote:I choose command EXPORT and I save the picture. XnView save the picture without expansion JPG. Program behaves on several just the same computers. Why?
Extension you means?
Yazor
Post by Yazor »
I must inscribe expansion JPG. However, I have noticed, that it takes a stand in case of record only for some folders
Go to Tools » Options... » General » File Operations and activate the If no extension, add it checkbox.
