custom LUT conversion
mshapcotte
In XnView, there is an option under Read -> DPX/Cineon to specify a LUT for 10-bit log to 8-bit linear conversion. Is there an nconvert command line option for filtering Cineon files through a particular LUT when converting to an 8-bit linear file format?
Re: custom LUT conversion
Ok, i'll add LUT in NConvertmshapcotte wrote:In XnView, there is an option under Read -> DPX/Cineon to specify a LUT for 10-bit log to 8-bit linear conversion. Is there an nconvert command line option for filtering Cineon files through a particular LUT when converting to an 8-bit linear file format?
mshapcotte
excellent! thank you for considering it. how long would that sort of addition take to find its way into the irix distribution?xnview wrote:Ok, i'll add LUT in NConvert
Please, send me a mail to my email address, and i'll send you a beta version.mshapcotte wrote:excellent! thank you for considering it. how long would that sort of addition take to find its way into the irix distribution?xnview wrote:Ok, i'll add LUT in NConvert
