Desktop located folders
AlterMann
Post by AlterMann »
If i click a subfolder of a desktop-located folder in thumbs panel (file list), tree view goes to its original location. (\Documents and Settins\*user*\Desktop)
Well... it shouldn't. :o
Version 1.91, Windows XP
Re: Desktop located folders
AlterMann wrote:If i click a subfolder of a desktop-located folder in thumbs panel (file list), tree view goes to its original location. (\Documents and Settins\*user*\Desktop)
Yes normal, XnView use real pahtname
AlterMann
Post by AlterMann »
I think i didn't describe it correctly.
We can find desktop-located folders in two different locations (in folder trees): One, under the "Document and Settings".... and the other, in Root. Right?
The problem is: If i double-click a subfolder on root path (from file list), it didn't expand folder in this path. Instead, it jumps to other path.
Try this: Create a folder and subfolder on your desktop. Double-click that subfolder from XnView's file list.
