crash if saving uncompressed thumbnails
Post by Guest »
hello,
the first dir where i save uncompressed thumbnails will crash in xnviews browser when i move to another folder and then back to this one!
im using xp sp1
is it faster on a slow machine if you save them uncompressed?
something else, if i access a dir with pictures already cached in the xnbrowser, everything is blinking for 2 blinks of an eye, which is a little annoying.seems the screen is refreshed to times very fast..
ckit
Re: crash if saving uncompressed thumbnails
Post by ckit »
Anonymous wrote:hello,
im using xp sp1
I can't re-produce any of this, however this is my first time using the cache feature in XnView and I prefer the Lossless ZIP compression. I did try testing the No Compression as well.
What do you mean by slow machine - Hard disk or CPU?
<Moderator's Note: Post has been edited.>
Anonymous wrote:the first dir where i save uncompressed thumbnails will crash in xnviews browser when i move to another folder and then back to this one!
im using xp sp1
Try to delete all files in XnView/cache folder?
Post by Guest »
yes it worked, but again if the thumbnails were saved in uncompressed form it crashes when i go to this directory via the thumbnail browser (when clicking on the dir icon ".."
there is no problem if i save them in zip...
both pII 400+udma33
and the blinking? double cklick on the picture to view it and double click back all the thumbs are flashing 2 times ..
ckit
Post by ckit »
Anonymous wrote: yes it worked, but again if the thumbnails were saved in uncompressed form it crashes when i go to this directory via the thumbnail browser (when clicking on the dir icon ".."
both pII 400+udma33 and the blinking? double cklick on the picture to view it and double click back all the thumbs are flashing 2 times ..
I still can't re-produce this problem, can you create a screenshot of the crash?
As for the blinking, again I don't have that problem.
