when using "add folder" option XnView can't see dpx files in root and subfolders. But it shows jpgs or tifs. I can manually add dpx files using "add" options and then it works! But in this case I have too many folders and subfolders.
THX for any help,
greets. MR
multiple files converter - DPX problems
M__R
if its not too clear what is my problem, I try again. The thing is I can't select folders with DPX files to convert these. As I wrote before I have huge ammount of folders with dpx to convert (my diploma movie).
Probably I'll have to make it manually, which is quite pain in the ass, but solution of this problem could be helpful in the future.
Greetings,
MR
Greetings,
MR
