Can I change or edit Image/Canvas resize custom settings?
LegoPete
Post by LegoPete »
I would like to be able to have the option to select some of the newer screen resolutions from the resize requester - widescreen formats like 1680 x 1050, instead of the usual 1280 x 1024, etc. Is there any way to edit these options?
Pete
ckit
Post by ckit »
While I don't have a widescreen monitor, I support this request!
Re: Can I change or edit Image/Canvas resize custom settings
LegoPete wrote:I would like to be able to have the option to select some of the newer screen resolutions from the resize requester - widescreen formats like 1680 x 1050, instead of the usual 1280 x 1024, etc. Is there any way to edit these options?
You means the size in the combo list?
LegoPete
Post by LegoPete »
xnview wrote:You means the size in the combo list?
Yes, the "Custom" drop-down list of screen resolutions followed by percentages.
Regards,
Pete
Danny
Post by Danny »
Just choose Custom and type it out in the fields below....
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
LegoPete
Post by LegoPete »
:arrow: Danny
Yes, I realize that it can be done this way. However I would prefer that there be a predefined screen resolution - much quicker. It would be nice to be able to completely customize the drop-down to have only sizes and percentages that one uses fairly often - I don't use any of the 4:3 or 5:4 screen resolutions, and I rarely increase the size of an image (>100%).
Regards,
Pete
LegoPete wrote::arrow: Danny
Regards,
Pete
So which size do you want to see in this list?
JohnFredC
Post by JohnFredC »
Here is a similar request from a long time ago!
John
LegoPete
Post by LegoPete »
xnview wrote:So which size do you want to see in this list?
Widescreen resolutions please; 2560x1600, 1920x1200, 1680x1050, 1440x900, 1280x800. There are a few more.
Thanks,
Pete
