Does the software support the UTF-8 format Filename/Directory?
I am using Chinese OS and when I browse a Directory using Japanese name, will have error, but If I use "Windows Picture and Fax Viewer". It can be read as normal, is there is any setting would allow me to change the program to correct this?
Does software support UTF-8 format Filename/Directory ?
Re: Does software support UTF-8 format Filename/Directory ?
Currently not supportedhamwong wrote:Does the software support the UTF-8 format Filename/Directory?
