This is a very small suggestion: in Add/Remove Programs, GFLSDK is listed under "Uninstall GFLSDK". This is confusing because a user would normally be listed under "G", not "U". After all, any program could be listed under "U", by this system. So could it be changed so that the entry was just "GFLSDK," since the uninstall aspect is obvious. (The same is true of GFLAx).
Thanks.
Change uninstall name?
