EXIF viewer
Turmalin
EXIF viewer
Post by Turmalin »
An EXIF editor like the one for IPTC-Metadata would be very helpful.
regards
Turmalin
Re: EXIF viewer
Turmalin wrote:An EXIF editor like the one for IPTC-Metadata would be very helpful.
Yes, but it's not very easy to recreate EXIF data
Turmalin
EXIF Viewer
Post by Turmalin »
Pierre
What do you mean by recreating EXIF Data? Isn't EXIF a standard? As far as I see there are some problems with standardisation of IPCT data. Thats why i'm looking for (standardized) EXIF-data to import in my FileMaker database. I would be (very) happy with "UserComment" ( PSremote is using that) other fields of interest would be title, description, author, copyright etc.
Thank you for your great work with Xnview!
Turmalin
Re: EXIF Viewer
Turmalin wrote:Pierre
Turmalin
Yes EXIF data but not Makernotes in it!
