Userdefinable keywords in Search
Mike D
Post by Mike D »
I just started using XnView and loving it already. The interface is much better than IrfanView. I haven't used all the features yet but one that I have used is the search function. Is it possible to add a search keyword feature in a later release?
Thanks
Exists…
:) Hello !
- Just pressing F3 opens the Search dialog-box…
:mrgreen: Kind regards,
Search
Post by Guest »
Hi Claude,
Thanks for the reply. The current search does not allow for the searching of IPTC data like keywords. Is that possible as a future enhancement?
Thanks
:) Hi !
- The Search by keywords is a bit complicated to add, I guess…
Only the Author can reply to you.
:?: Pierre, any plan in that way ?
:mrgreen: K R
Re: ????
Clo wrote:- The Search by keywords is a bit complicated to add, I guess…
Currently, this feature is only in the Deluxe version.
Mike D
Search
Post by Mike D »
Pierre,
Any plans to add the search by keyword to this version? Just checking.
Still a good program.
Mike
Re: Search
Mike D wrote:Any plans to add the search by keyword to this version? Just checking.
Yes, a future version will have this feature.
Mike D
Search
Post by Mike D »
Looking forward to it. Thanks.
