Make the info text background in viewer semi-transparent
ilgaspa
Post by ilgaspa »
Right now is possible to make the info text (the one triggered with I key) background in viewer completely transparent or completely solid colour: would be possible to add an option to make it semi transparent, thus allowing te text to be readable while still being able to view what's behind?
Re: Make the info text background in viewer semi-transparent
ilgaspa wrote:Right now is possible to make the info text (the one triggered with I key) background in viewer completely transparent or completely solid colour: would be possible to add an option to make it semi transparent, thus allowing te text to be readable while still being able to view what's behind?
Already in my TODO list :-)
