Text in tooltips that's displayed only if needed
ilgaspa
Post by ilgaspa »
I have two digicams: one stores ISO data in the standard field, whilst the other uses a proprietary one. In tooltips I set the ISO value to be shown as follows
ISO:<ISO>
but this results in the word ISO: appearing even if the image has no iso data... perhaps a syntax like foobar's one, something like
[ISO: <ISO>]
would be useful... the "ISO:" string should be displayed only if the <ISO> tag has exists
Re: Text in tooltips that's displayed only if needed
ilgaspa wrote:I have two digicams: one stores ISO data in the standard field, whilst the other uses a proprietary one. In tooltips I set the ISO value to be shown as follows
ISO:<ISO>
[ISO: <ISO>]
Yes, currently it's a problem if info doesn't exist.
[] is not good because is used often.
But one delimiter between the text is a good idea $ISO:<ISO>$
