JPEG Lossless transformation and date/time
helpix
Post by helpix »
When I use "JPEG Lossless transformation" from keyboard (Ctrl-Shift-L
or Ctrl-Shift-R) date/time of file not changed.
In dialog "JPEG Lossless transformation" checkbox "Keep original
date/time" is unchecked. But it work only for transformation from this
dialog, not from keyboard!
Checkbox "Tools/Options/General/File Operations/Keep date/time for
saving" not work for this operation too.
Version 1.91.1
Win XP Pro
Thank you. And sorry my terrible english.
Re: JPEG Lossless transformation and date/time
helpix wrote:When I use "JPEG Lossless transformation" from keyboard (Ctrl-Shift-L
You means that file date is changed with Ctrl-Shift-L or Ctrl-Shift-R???
helpix
Post by helpix »
Date/time not changed. Files are changed. They has other size and so on. But they has old date/time. Therefore all backup/syncronyze programs think that files not changed.
helpix wrote:Date/time not changed. Files are changed. They has other size and so on. But they has old date/time. Therefore all backup/syncronyze programs think that files not changed.
So you would like to change file date???
helpix
Post by helpix »
xnview wrote:So you would like to change file date???
Yes!
Yes!
And file date is always changed when you use keyboard in browser mode or view mode??
