file associations - add all
besonen
Post by besonen »
why when i select "Add All" is every file extension selected except "Sun Rasterfile" and "Windows Bitmap"?
Re: file associations - add all
besonen wrote:why when i select "Add All" is every file extension selected except "Sun Rasterfile" and "Windows Bitmap"?
Ok, they are added but all extensions are not added, this is the little bug (scr and ico)
besonen
Post by besonen »
xnview wrote:Ok, they are added but all extensions are not added
huh?
could you restate that? i don't understand "they are added but all extensions are not added". it reads like a contradiction to me.
huh?
I means that some extension are not added for conflict system
besonen
Post by besonen »
xnview wrote:
huh?
so, are you saying that the "Sun Rasterfile" (ras, rast, sun, sr, rs) and "Windows Bitmap" (bmp, rle, vga, rl4, rl8) formats are not selected when the "Add All" file association button is pressed due to some kind of conflict?
and if this is the case, could you tell me what type of conflict occurs when these extensions are associated with xnview?
-- david
besonen wrote: and if this is the case, could you tell me what type of conflict occurs when these extensions are associated with xnview?
The problem is .vga, .scr
