nconvert 4.79 segmentation fault when rotating
suki_babee
Post by suki_babee »
I noticed image rotations of arbitrary angles result in jagged edges, so I was happy to see the 4.79 release add a "-rotate_flag smooth" option. But I can't get it to work.
This works (with jaggies): nconvert -rotate 9 -o out.jpg orig.jpg
this produces the same result (I guess the smooth flag is not picked up) : nconvert -rotate_flag smooth -rotate 9 -o out.jpg orig.jpg
but anything specified after the "-rotate" param results in a segmentation fault : nconvert -rotate 9 -rotate_flag smooth -o out.jpg orig.jpg
for instance, this command works on ver 4.51, but segmentation faults on 4.79 : nconvert -rotate 9 -crop 0 0 100 100 -o out.jpg orig.jpg
output :
** NCONVERT v4.79 (c) 1991-2007 Pierre-E Gougelet (May 16 2007/10:54:38) **
        Version for Linux x86 (X11)  (All rights reserved)
** This is a freeware software (for non commercial use)
Segmentation fault (core dumped)
I am running the Linux x86 version on Ubuntu 6.10.
suki_babee
seg fault on basic crop too
I have not done a lot of testing, but I see that a basic command :
also seg faults on 4.79, but runs fine on 4.51. I can't be the first to notice something like this. Is nconvert dependent on shared libraries? What can I do to help isolate the problem / collect more info ?
Re: seg fault on basic crop too
suki_babee wrote:I have not done a lot of testing, but I see that a basic command :
Ok, i'll update a version...
