4.76 works fine on eps files, vs 4.79 not working? odd, help
Nilesh
Post by Nilesh »
I used v4.76, then i upgrade to v4.79 (linux x86).
the EPS to JPG converting fails,
EPS converting fails in 4.79 but works good in 4.76. (ODD huh?)
saying cant read file... yet when i used it on older version it works fine,
also notice a time lag issue in 4.79 it pauses for 30sec or something?
any suggestion or help? thank you!,
Re: 4.76 works fine on eps files, vs 4.79 not working? odd,
Nilesh wrote:Hello,
I have no problem with 4.79 under linux.
Which ghostscript version do you have?
Could you post the eps?
Nilesh
Post by Nilesh »
GNU Ghostscript 7.07 (2003-05-17)
Nilesh wrote:GNU Ghostscript 7.07 (2003-05-17)
And the PS file used?
Post by Guest »
Any EPS, not just one EPS,
i pick any EPS file randomly none of them works like older version.
i may upload a EPS file for your testing, yet its just a Normal EPS nothing unique about the file, for example any EPS i find off the Internet would do.
Thanks,
Nilesh
Nilesh
Post by Nilesh »
Thanks,
Nilesh
Nilesh wrote:Any EPS, not just one EPS,
Thanks,
Nilesh
Sorry i've tried but without problem...
